Whore’s drawers is the standard metaphor….
I considered that, and searched for a 'at a ...' to finish the sentence, couldn't think of one so abandoned the whole idea.
Does it not state in the Triumph manual that it should be between the two levels?Checked fluid levels on the Thruxton and had to top up the oil with about 150ml to get to upper level
Does this sound normal using this much oil in 6 months / 3,000 miles??
Or the beginnings of something sinister
Yes it does, but was well below the lower level so filled it up to upper point which when run and left to settle gets me to just over the mid point in the inspection windowDoes it not state in the Triumph manual that it should be between the two levels?
MMmm, I would run it get it warm check all over for any oil leaks and also the smoke for signs of burning oil, after a good run [hard this time of year] check again and plugs for oily residueYes it does, but was well below the lower level so filled it up to upper point which when run and left to settle gets me to just over the mid point in the inspection window
I'd fill it too the upper line Nick. Then check it once a week & take a note of the mileage at each check.Yes it does, but was well below the lower level so filled it up to upper point which when run and left to settle gets me to just over the mid point in the inspection window
Cheers Don I think that’s a good idea, should be able to get a good run out this week in daylightMMmm, I would run it get it warm check all over for any oil leaks and also the smoke for signs of burning oil, after a good run [hard this time of year] check again and plugs for oily residue
I won't be insulting and ask about the right oil
Cheers Jez I’ll do that as well - and yes checking on the patio which is definitely not billiard table smooth or flatI'd fill it too the upper line Nick. Then check it once a week & take a note of the mileage at each check.
Ensure that the bike is in exactly the same place when you check the oil level.
If you're checking it on your patio? There's a chance that not all the slabs are billiard table flat.
As for your question of is 150ml in 3000 miles normal? I'd say no mate. I like to see zero oil usage between services.
She’s done 26k and I haven’t noticed smoking (although now I will be looking) also haven’t seen any leaks - certainly nothing where she’s parked at homeHow many total miles? I would be inclined to suspect an error in original measurement if you’ve no leaks or smoking. (Oil filter?) On a low mileage bike you can sometimes find leaky rings because it has never been thrashed enough to bed in. It’s a bloody good fun way to see if it smokes!
No mate I rarely run her when she’s on the stand but it’s an interesting pointDo you run her regularly on the stand (possibly side stand) when not in regular use? A lot of bikes and particulary my Triumph triples seem to use a eat oil when they are kept regularly 'turned over' during the winter. I believe this is a common observation on the triples at least. Maybe it's a liquid cooled thing as my Bonnie's don't use a drop.
The Triples that we own are known to be greedy for a bit of oil. Some engines are, 80s Kwaks were oil hungry iirc.Do you run her regularly on the stand (possibly side stand) when not in regular use? A lot of bikes and particulary my Triumph triples seem to use a eat oil when they are kept regularly 'turned over' during the winter. I believe this is a common observation on the triples at least. Maybe it's a liquid cooled thing as my Bonnie's don't use a drop.
Your 1050 triple is a more modern version than Chas & Marty have in their bikes.If my 1050 is drinking it’s in sips!
