T2502109 Relay EFI | Genuine Triumph Motorcycle Part |
Cor blimey £22 new...
@Don the Don what was that place called you recommended before where I got the brake lever micro switch from....
A quick Google search says it's a Hella relay & they are used on several Mercedes & Nissans.
Wemoto
My guess is something along the lines of...you need to mark down the No's on the relay Duck let us know what's on it
These relays Duck are all coming in at about the £21-£22 from Triumph, I think @DD67 's idea off it being Hella may hold some water try Hella direct [webb site] or even take one to a motor outlet you need to mark down the No's on the relay Duck let us know what's on it
01RA001
4RA940010
Don't take that as gospel though Duck. But compare it with the current relay.
Mrs Duck will turn you into a frog if she finds out you've been squandering your/her money again!I bit the bullet and bought one from Fowlers ...
I can only hope this relay resolves the problem...
I've already had the lectureMrs Duck will turn you into a frog if she finds out you've been squandering your/her money again!
Two words, second word "OFF"I've already had the lecture
Did the lecture involve phrases such as...I've already had the lecture
That's you turned into a frog as well!Two words, second word "OFF"
We don't stand aloneThat's you turned into a frog as well!
At least Duck will have some company
Ooh... you'd be turned into a frogTwo words, second word "OFF"
She basically said you got no choice but to keep spending on it as you can't afford to do anything else or replace it with anything else so your stuck with it...Did the lecture involve phrases such as...
..."That bike is a money pit! Get something more reliable"...
..."The feckin thing is the two wheeled equivalent of Triggers broom!"...
If so, you should listen to her. Do frogs have good or bad hearing? Can't say I've noticed ears on frogs?
Great minds think alikeThat's you turned into a frog as well!
I actually like that song...Maybe it could be used as a method of calming me down when I start losing it...We don't stand alone
You utter, utter bastard.On the subject of music please tell me you don't have 'Disco Duck' as your anthem
