Christ mate! Are you doing abortions now?View attachment 15360quick coffee and quack on...
I'm now currently on jamesons whiskey coffee to calm my temper and about to see if my special job specific tools fix my fairing on my bike...
They bloody well better is all I can say
Now that's an idea to earn a couple of extra quid on the side..Christ mate! Are you doing abortions now?
Talking of angle grinder solutions...Remember, coat hanger, not angle grinder!
Put some Swarfega in the hole. The grommet should go in easier.Talking of angle grinder solutions...
I'm currently trying to fit this indicator rubber grommets malarkey into that hole on the fairing..now I'm not exactly known for my patience and finesse...why won't it fit and should I make the hole bigger or just strip the versys naked with the angle grinder and weld my ammo boxes onto it..
I tried all sorts..I'm gonna try heat gun to make it more pliable...Put some Swarfega in the hole. The grommet should go in easier.
At least you've had one good idea todayPlus a glass of Bushmills 10yr old whiskey
"Bomber Command" not been called that since 68, it was then Strike Command now One Group, Someones pissed you off I take it @BAD LUCK DUCK@Don the Don Mate I need you to use your contacts at bomber command and launch all our bombers and place them in holding positions to attack China
Allways best to lubricate both partsI tried all sorts..I'm gonna try heat gun to make it more pliable...
