I also did all you have done on my sprint but also replaced fuel rail and injectors..Here's a question for the brains trust - Could contamination, such as oil or something else, reaching the cylinders cause a bike to run really badly or even refuse to run at all? I've been fighting with the Daytona for a while now as she started running really lumpy and then refusing to run at all. Changed the fuel pump, fuel filter, coil packs, injectors, throttle position sensor and throttle bodies for spare used ones and changed the Sparkers for another used set that had been good when last used to no avail although that did get her running for a brief few seconds, albeit very lumpy. IACV stepper motor seemed to be working OK so I was flummoxed. As a last ditch tonight I pulled the plugs and, recalling an old trick, hit them with a blowtorch, drained the tank and put a few pints of fresh fuel I had picked up from the petrol station t'other day in. She started and kept on running and now sounds like she is back to normal although the tick-over is a little ropey but that should reset if the engine is run up to operating temperature at idle.
In the end after all thst our @Scrappy turned up with a tune ECU malarkey me Bob and reset the ECU map and it ran brilliant after that...
