Well, I was trying to run her up until the fan would come on at least once a fortnight throughout the winter. About February or so she suddenly seemed to become a little harder to start which I put down to a slightly colder spell and put the battery on charge. Then, next time or two she started fine although she was never as quick to start as the Sprint but I'm told the more highly tuned version of the motor used in the Daytona has a reputation as a difficult starter. Let's say that the next time, maybe a early April or so she took ages to start and sounded like she was only running on two cylinders but tried her again later that day and she was back to normal. Since then she would be very awkward to start but, once started and warmed up she would start no problem but, allowed to cool down again she would then be a bitch to start once more and, finally she simply refused to start at all although, for a brief period as I mentioned previously she sprang back to life and ran normally until the fan came on at which point I stopped her and, next day she wouldn't start and hasn't even sounded like she's trying since. During that time I've changed the plugs and coil packs, then the injectors, then the throttle bodies, changed fuel pump and filter and even tried the IACV valve from my Sprint which I know is working perfectly all to no avail.
My next move is to check that all three coils are sparking, pull the injector bodies/fuel rail from the head and see if it's squirting properly when I prod the starter. That may throw up something I suppose. After that I can program the spare ECM I have, it's a Sprint one but I can give it the same map as I have on the Daytona. After that the easy options will be to swap the sub-loom that feeds the injectors, IACV, TPS and Crank position sensor then I suppose I can swap all the Lambda, Crank position and Coolant sensors for my spares. If none of those are the culprit then I am left with valves or camchain somehow having slipped. I doubt the camchain would be at fault as, from what I gather on these motors the valve timing being even slightly out would mash the valves into the pistons and there was no undue camchain noise even when she was running lumpy. None of it is really difficult or tricky just time consuming and a pain in the ass. I do wonder if the Lambda sensor could be the culprit. Possibly carbon buildup from running on the spot without a good outing?
