There are innumerable Clachans! It means hamlet, I believe. Do I qualify for a cigar?
I used to love port issac....Heard it's changed a lot since I was last there twenty years ago...Had to take the Himmy out, to get some sunlight vit D, and put some "essential" running in miles on the engine.
Went to Port Issac. The village is used in the Doc Martin series!View attachment 4002View attachment 4003
Completely deserted..... Not a single "Grockle" to be seen!
We used to visit a lot in the early 80's. It was always a pain to park when visiting.I used to love port issac....Heard it's changed a lot since I was last there twenty years ago...
Hamlet? Cigar? Was I too subtle? Were you too far down the bottle?No cigar I'm afraid. There are indeed many Clachan's but there is only one at the upper end of Loch Fyne. The Gaels tended to use the same descriptors in numerous areas hence there are a number of Tarbet's/Tarbert's as the name simply means a narrow strip of land between two bodies of water such as the strip of land between Loch Long and Loch Lomond or the narrow strip of land between Loch Fyne and the Atlantic Ocean. Then you have the numerous Ben More's as the name simply means 'Big Mountain'.
On a side note I wonder if Clachan, and nearby Cairndow will see somewhat of a growth spurt in the next few years as Scotgold have been doing survey work in upper Glen Fyne and they have stated that they believe there is much more gold in them thar hills than at their mine at Cononish.
You're forgetting that not everyone here is over sixty. I believe Mr Martian has yet to attain fifty years on the planet so references to 70s tv adverts may be lost on himHamlet? Cigar? Was I too subtle? Were you too far down the bottle?
My Dad teased me as Canmore. Great Chief? No, Big Head!
That was a waste of time then!Been in the garage all day fettling & making new lower fairing mounts, now all bodywork back on & she’s ready to go. Started first push of the starter, not bad after being idle since last race in September.
Have a look at the stuff on the bench getting the V Twin treatment when I blip the throttle!
Does it have to be distilled or is that just your pref? I always mix up coolant with distilled water on any vehicle i give a shit aboutThat was a waste of time then!
Track day on March 22nd won't happen, looks like the first time I will ride this year will be at test day for Brands race weekend, not ideal but restrictions & work commitments mean I just won't get a trackday in.
I had left the coolant in the system as it's fine for track days but you need to have just distilled water for racing, I prefer coolant as it a) doesn't freeze and b) has lubricating properties for the water pump. So will need to take the bodywork back off & change to distilled water.
It's is up to you whether distilled or tap water, however I always use distilled as the tap water round here is hard & would leave the inside of the cooling system looking like the before picture on a Calgon advert!Does it have to be distilled or is that just your pref? I always mix up coolant with distilled water on any vehicle i give a shit about
Also distilled wata has a higher boiling point, I think.It's is up to you whether distilled or tap water, however I always use distilled as the tap water round here is hard & would leave the inside of the cooling system looking like the before picture on a Calgon advert!
When I think cigar I must admit that Hamlet isn't the first name that comes to mind
Looks a tidy jobClutch cable on, so just need to put tank on and check everything is running fine now.
Then bodywork back on and job's a good un!
Also had a result dealing with the brake guard issue and having blocked off bars.
Managed to get a brake guard that fits on 22mm bars, and then got a friendly biker neighbour to machine down a bar end weight for it to fit.
So can now simply swap bar end weight and fit guard when I am doing a trackday
View attachment 4050View attachment 4051
Looks a tidy job
