Is this like spot the ball? How many goes do I get for a quid? What's the prize this week?Just spotted a buzzard in my photo, the one with the headlights in view. (not the buzzard with the headlights)
Looking good, they don't make it easy do they.
When I checked Fowlers for the part number of the eBay rail there was a seat included in the kit but I thought it was 'for illustrative purposes'.Looking good, they don't make it easy do they.
I didn't...
I think you done really goodWhen I checked Fowlers for the part number of the eBay rail there was a seat included in the kit but I thought it was 'for illustrative purposes'.
Def 'FFS' moment this morning when I realised that the seat wouldn't close. As it was it was easy to see what bit needed removing, there was a moulding seam that indicated where to cut. I'm guessing the base mould for the pan had a bit added in for Grabrail/Non Grabrail.
I'm pleased I did not fuck it up
The cunts.I take it that Triumph did this sort of thing with all their single/twin seat sports machines. I have seen the single seat hump for the Triumph Sprint RS both with and without a cut out for a rear rack or grab rail and I have seen saddles with and without the same cut-out.
I like a grab rail for manhandling the bike around and it's a locus for bungees when carrying shite. I don't often carry a pillion, usually one of the daughters but they (and I) prefer bracing against a grab rail rather than trying to find a bit of riders fat to grab if I am too quick with the throttleI suppose I can sort of see their point from a functional point of view although I think a machine set up for single seat looks a bit odd with a rear rack (not a fan of shopping racks on hooligan machinery or any bike to be honest) or being able to quickly remove your seat hump and take a passenger and provide them with something to hold onto other than the pilot bit I think it also must make them a good dollop of cash in aftermarket parts.
Serves you right for not being a monogamistI am falling out of love with early 2000's Triumph Sprint RS's. Today I took my black one out for the first time since removing the tank to dry it out and try and get rid of the blisters which was a failure. During that process I had to fix the fuel sender as the wires had snapped off at the base of the unit due to old age. Out today I discovered another 'interesting' problem has now developed. She won't idle intermittently and, if I pull in the clutch and don't keep the revs up she will die on me. I am guessing that the Idle Air Control Valve is rearing it's ugly head.
Also suspect the throttle position sensor.I am falling out of love with early 2000's Triumph Sprint RS's. Today I took my black one out for the first time since removing the tank to dry it out and try and get rid of the blisters which was a failure. During that process I had to fix the fuel sender as the wires had snapped off at the base of the unit due to old age. Out today I discovered another 'interesting' problem has now developed. She won't idle intermittently and, if I pull in the clutch and don't keep the revs up she will die on me. I am guessing that the Idle Air Control Valve is rearing it's ugly head.
I replaced the rubber gasket..Got some hose off Ebay to replace the three IACV hoses which I only just replaced with solid genuine triumph corrugated hose which actually genuinely made a difference but the only real solution to the problem your experiencing now was to manually adjust the throttle position sensor....Thanks for the tip @Tallpaul I will check that out too. I am definitely not a fan of all this computer controlled, fuel injected with a thousand and one sensors nonsense that is the 'modern' motorcycle. Instead of a few hundred 'failure points' it now seems that the average bike has thousands.
