Quite a bit north of me
@Freck I believe that
@Tallpaul is currently somewhere around Fort William. It is another real nice slice of Scottish country around those parts.
I'm afraid I am not sure whether the bike is on the standard map but possibly not. Someone amongst the previous owners seems to have boned up on their Daytona's as it appears to me that the reg/rec and, I presume, the alternator, have been replaced. Interestingly on that front I just read tonight on the Daytona facebook page that some guy had his reg/rec replaced by the dealer and they used one for a 675 which they said solves the problem. Has anyone else heard this?
I have fed some injector cleaner into the fuel
@Sarky B’stard and the run today was partly to get that going through as the Injectors occurred to me too. I have been wondering if it might be a dodgy fuel pump but I would have thought that that would show up an error code. First time it happened I stuttered along for a couple of minutes and then it suddenly cleared itself. This time I stopped and switched her off and on a couple of times wondering if it might be a dodgy ignition or kill switch as both times it happened when starting up again after stopping. I might pull the fuel feed system out of the tank and replace the fuel pump with the one from my scrapped Sprint and see if that solves the problem, Every part in the fuelling system is shared with the Sprint so I have an entire set of spares that I can substitute in to see which one is causing the problem. I have read online that it's possible, if syphoning the fuel tank, to nudge something inside the tank that can cause problems but I haven't done anything like that myself and I doubt that, if that was the case, it would only happen occasionally.
